Old 04-28-2009, 12:38 PM
Nechochwen's Avatar
Nechochwen Nechochwen is offline
profundus tergum
Originally Posted by Zoom View Post
Where is the Walnut Brewery?
It's here in boulder, near pearl street.
Old 04-28-2009, 09:15 PM
AndrewF's Avatar
AndrewF AndrewF is offline
MIiA
Absolutely beautiful shots, Zoom!
Old 04-28-2009, 09:31 PM
Zoom's Avatar
Zoom Zoom is offline
Twin 2.0
Thanks! Hey, any tips for how to better balance a very milky sky with a darker scenery so I don't get those wierd glowing purple lines around subjects? Or just tips in general?
Who needs sleep?
CrazyDog Photography CrazyDog on Facebook
Scent Sweet Home--Scentsy Wickless Candles Follow me!-Spring/Summer 2013 catalogs available!
Have Aussie, Will Travel--A Blog updated 5/26/12
Thanks Alliemackie!
Old 04-30-2009, 07:06 AM
AndrewF's Avatar
MIiA
Hey Zoom,
There's a couple of ways to balance out the sky with the foreground. My preferred method is to use a graduated neutral density filter to restrict light on the top half of the frame without darkening the bottom. You can also shoot the scene deliberately dark, maintianing detail in the sky and then bringing up the detail in the fore-ground in post-processing (see my comments below about contrast/histogram). Lastly, you could shoot several shots from a tripod so they're all the same framing. Shoot one to expose the shadows only, one to properly expose the sky only and one or more at intervals in-between them. Keep the aperture the same and adjust shutter speed. Blend the exposures in photoshop (some labour required) or a program designed to do HDR (select the group of images, sit back & sip coffee or other drink of your choice, then admire/tweak the results once the blending is finished.
If I don't have a filter with me or I can't use it, I turn the contrast all the way down in-camera and will shoot the scene making sure I don't blow the highlights. However, you have to make sure you don't under-expose the image too much. If you're in this position, you need to use the histogram when you review your shots and not the actual results on the LCD. You have to make sure that your histogram is as close to the right without going over....in fact you probably want the bulk of the histogram to the right. Shadows in the photo can generally be recovered this way (with minimal noise hopefully) and your highlights remain in tact. Whatever you do, don't blow the highlights because once they're gone, they're gone. shadows can always be recovered.
The spot that appears in your sunset shot also appears in a few other photos. I suspect your lens is fine and that you've got dust on your sensor. This is pretty easy to correct in most cases by simply blowing the spot off (with a blower, not by blowing). If that fails, there's a whole bunch of sensor cleaners out there which range in price from pretty cheap to pretty expensive. One of the tricks I used (though I don't recommend it per se) is to get scotch tape (not the clear stuff, but the 'milky' tape) and lay it across the sensor and then remove it. It's not strong enough to damage the sensor, but it will get all the dust. That said, I don't really recommend this as over time it could leave a residue. Currently, I'm using a product called dust-aid. It works very well and is about mid-range as far as price goes. I've used it several times including in the field (again, not really recommended) to get rid of dust spots that screwed up a couple of images.
For the purple lines around subjects, I think you're referring to purple-fringing (I didn't see any in your photos though). Unfortunately, when you've got a sky on the verge of blowing out and dark lines, you're pretty much going to get fringing (depending on the lens I get purple or green) The easiest method I know of to remove that is in any form of photoshop (and probably most other programs), using the hue & saturation, select the dropper tool and click on a part of the fringing. Then desaturate it & if needed, adjust hue so it matches the background. Keep in mind, I've pretty much stopped using photoshop so my recollection could be a bit off on the exact steps.
Old 04-30-2009, 09:04 AM
Zoom's Avatar
Twin 2.0
...I still have a LOT to learn about my camera...I typically stick with shooting on S-priority and I still haven't gotten aperture completely figured out, so I'm not sure how to freeze that and adjust shutter?
Who needs sleep?
Thanks Alliemackie!
Old 04-30-2009, 11:58 AM
AndrewF's Avatar
MIiA
If you want to play with the aperture settings, you want to change from S-priorty to Av or A priority (not sure how your camera identifies this). Your scroll wheel should then adjust your aperture values.
Saje did a good thread on depth of field a while ago. That should give you a good starting point because your aperture controls how much light comes through the lens and how much depth of the photo is in focus.
On your lenses, f/3.5 will let in the most light. It will also give you the least amount of depth of field. F/22 will let very little light in but you will have a good deal both near and far, in focus.
Old 04-30-2009, 12:00 PM
Zoom's Avatar
Twin 2.0
Well, the best thing about living around here so far is there is no lack of subjects to practice on!
Who needs sleep?
Thanks Alliemackie!
Chazhound members save 10% on electric training collars from www.pet-super-store.com by using coupon code "chaz."
