I thought this was a pretty good article (written by a vet) about what to do in the case of suspected poisoning in an animal. It's from the Dolittler blog which can be found here.
The ASCPA comment is one I didn't know. Will have to keep that in mind. Quote:
Cleverly disguised as a responsible adult. "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, throughly used up, totally worn out, and loudly proclaiming --- 'WOW, WHAT A RIDE!!!!' " - Author Unknown
Good post, especially at this time of year if you live where it's cold and need antifreeze in the car. this is extremely poisonous to both cats and dogs, so please be sure to check the driveway for any possible leaks from cars.
Thinking about getting your car winterized this fall? Antifreeze is 95% ethylene glycol, (an important chemical used to prevent your car’s radiator from freezing or your windshield from icing) which is toxic to most animals although dogs, and to a lesser extent cats, appear to be primarily affected. Improper storage and handling of this chemical often leads to poisoning of pets since it has a sweet taste that may be attractive to animals. Most poisonings are accidental, but unfortunately, malicious poisonings may also occur. There is a seasonal nature to the toxicity, with poisoning seen most commonly in the fall and winter when antifreeze is most commonly used.
The chemical formula for ethylene glycol is C2H6O2. It is a colorless and odorless liquid. Antifreeze poisoning is the second most common cause of fatal poisoning in animals according to the American Association of Poison Control Centers. Ethylene glycol is also present in hydraulic brake fluid, motor oil, inks, paints, and wood stains. The mortality rate in dogs poisoned by antifreeze ranges from 50 to 70% and is thought to be even higher in cats. A relatively small dose of ethylene glycol is necessary to cause the death of a pet. The minimum lethal dose of ethylene glycol is 4.4 ml/kg in dogs and a mere 1.4 ml/kg in cats. Antifreeze is quickly absorbed from the digestive tract with peak blood concentrations occurring within three hours of ingestion. Absorption may be delayed when food is in the stomach. Approximately 50% of the ingested ethylene glycol will be excreted unchanged by the kidneys. The other 50% of ingested ethylene glycol is metabolized by an enzyme called alcohol dehydrogenase (ADH) in the liver and to a much lesser extent in the kidneys, producing toxic metabolites which cause severe metabolic acidosis and kidney failure. Glycoaldehyde and glycolic acid are thought to be the metabolites primarily responsible for the toxicosis. Clinical signs of antifreeze toxicity mimic those seen with marijuana, methanol, or ethanol (alcohol) intoxication. The patient will vomit due to GI irritation; they tend to have increased thirst and urination and may exhibit neurologic clinical signs. Neurologic signs are those attributed to the central nervous system, including depression, ataxia (unbalanced), stupor, and an inability of the pet to get up or right itself. Clinical signs of acute kidney failure occur 12 to 24 hours following ingestion in cats and 36 to 72 hours in dogs. These animals will no longer urinate because they are unable to manufacture urine. They will be lethargic, anorexic, and dehydrated, develop oral ulcers, salivate, and possibly have seizures until becoming comatose. Urine production gradually decreases until no urine is being produced. The kidneys are often swollen and painful. Hyperphosphatemia (high phosphorous levels in the blood) may be seen within 3 hours of ingestion. Commercial test kits may detect serum concentrations of ethylene glycol 1 to 2 hours after ingestion. Kidney markers BUN and creatinine begin to increase 12 hours after the ingestion of ethylene glycol. Hyperkalemia (high blood potassium levels) corresponds with the decrease in urine production. Approximately 50% of affected patients will have low levels of blood calcium and increased levels of serum glucose. The prognosis depends upon the dose of ethylene glycol originally received by the patient and the time lapse between ingestion and the administration of treatment. In dogs, the prognosis is good when the toxicosis is recognized and treated within five hours following ingestion. This period is shorter in the cat, with treatment needing to be instituted within three hours of ingestion for the prognosis to be good. An ethylene glycol toxicosis may be recognized by the development of calcium oxalate crystals in the urine 3 to 6 hours after ingestion in the cat and dog, respectively. These crystals appear as a clear six-sided prism. The blood or urine may also be tested for the presence of ethylene glycol. Serum concentrations of ethylene glycol peak 1 to 6 hours after ingestion and will no longer be detected after 48 to 72 hours. Serum osmolality may be measured one hour after ingestion for the detection of ethylene glycol and will remain high for up to 18 hours after ingestion. Many antifreeze solutions today contain sodium fluorescein, a florescent dye that aids in the detection of leaks in automotive coolant systems. A Wood’s lamp or black light may be used to detect fluorescence from the fluorescein stain in the oral cavity, face, vomit, urine, and coat. The dye is excreted up to six hours following ingestion of ethylene glycol in the urine. __________________________________________________ __________________ Pittsburgh Pay Per Click web design bucks |
this is a well written article. i believe that dog owners should not shy away from their responsibilities of ensuring the safety of their lovely pets. Adequate attention mustv be given to the pet. thanks once again.
Nice, a very useful one like me who really don't have that enough knowledge when it comes in handling that kind of situation that will happen to my pets.
Try to visit this also a very helpful site on how to handle pet poison care Dog Poison Care |
This is a great article, thanks for sharing! Just to add to this, there are a lot of human foods that dogs love to eat which are poisonous at the very least dangerous to them if they eat too much. Among which are:
- alcohol - chocolates - tea, coffee, anything w/ caffeine - human medication - avocado - grapes and raisins We need to be extra vigilant with our dogs as they love human food!
You're About To Discover Secrets About Clicker Training Almost No One Knows About – Click Here |
This past Halloween my dog got into a bag of chocolate candy and pretty much ate the whole bag. I when immediately online and found that many people said to use hydrogen peroxide to induce vomiting. I gave him only 2 tbs and in minutes he barfed up everything including rappers. It really worked and I felt so much better that I was able to help him and not have to go to the emergency vet.
Looking for a grain free treat? visit my website, Home Page |
Very nice. It is always pleasure to read such an informative article to get info from...
Have You Submitted A Photo Of Your Dog To *Win Free $1000 For The Cutest Pet* Yet? |
Most of the impact of food poisoning to be in small dogs, including the recently discovered for the dog food poisoning, can cause liver damage and even death xylitol sugar-free candy fatal. Many cases, may even be toxic to dogs and other common food pet owners must beware when feeding their dogs.
