Old 11-26-2008, 09:05 AM
Default bandaging
I found this link and thought maybe it would be a good idea to sticky it.
http://www.basc.org.uk/content/bandaging_part_1 ears
http://www.basc.org.uk/content/bandaging_2 feet
http://www.basc.org.uk/content/gundogs2/gundogs tail
Old 11-26-2008, 09:13 AM
Good sites Smkie ! Thanks !
Old 11-26-2008, 09:29 AM
I had one magazine that should this in detail but i couldn't find it so i tried to find it on line. THere was another long one on first aid but it was a pdf file and you had to go through the whole thing. It was very informative tho and if i can find it back i will add it to this link for it covered all first aid measures.
Old 11-27-2008, 03:19 AM
GlassOnion's Avatar
Thanks, and Gig 'em.
Just two things to add and it didn't look like they addressed this. You want to wrap from the middle up, then down. It says to wrap from the bottom up which is technically correct but it works a whole lot better to start in the middle and get immediate pressure on the wound. Also helps keep the gauze/padding/Telfa/whatever that's directly on the wound to stay without needing a third arm.
Second thing is to wrap from the inside towards the outside. The Red Cross says to do it from the outside to the inside but if you do it that way you can skew tendons to the inside. This may not be a big deal in humans (I don't know) but it can be in horses, dogs, etc.
Old 11-27-2008, 08:42 AM
CAN you explain the last one GO i may be dense this morning but inside to the out?
Chazhound members save 10% on doggie doors from www.pet-super-store.com by using coupon code "chaz."
