Old 10-04-2012, 05:48 PM
Dogdragoness's Avatar
Please click my eggs :)
Originally Posted by sparks19 View Post
I am extremely responsive to birth control. I have been on it off and on since 15, definitely had times where I was not taking exactly correctly (as far as same time everyday, some days i would even forget and take two the next day) and never had it fail. I did get pregnant once prior to hannah but that wasn't a BC fail that was a being responsible fail and most here know how that ended.
I have not been on BC since I found out I was pregnant with Hannah and have pretty mich been following my ovulatiOn cycles and what not and no surprise yet. My body is pretty easy to plan around lol. I am super regular. But we realize this is risky and know a baby is totally possible and we are prepared for that just in case
Yeah, me too, i know my body & can "tell" when i am ovulating & when I am "close" to bleeding, i mark my cycles on the calender (even mark the days for 21 & 35 days because i know a cycle can start that early or thsat late) so i try not to have sex when i am ovulating even tho i use condoms. I am 30, & if i had insurance, i would get sterilized because i KNOW that i DO NOT want any kids EVER for certian... but even then i would still use condoms LOL
Thanks for clicking!
Old 10-04-2012, 06:02 PM
sparks19's Avatar
sparks19 sparks19 is offline
I'd rather be at Disney
Originally Posted by Lyzelle View Post
It doesn't work that way in the medical feild. Under that logic, you are saying every woman induced into labor with Cytotec and lost their child and/or their lives was completely their fault.
As a healthcare provider, the top priority is GIVING INFORMATION. If it wasn't, why bother having doctors?
That is hardly what I am saying at all... But I suspect you knew that. B
I agree doctors should give info but when your doctor prescribes something do they sit there and go over every single bit of info about that drug? Not usually because A) they usually have one hundred other patients just like you demanding to be seen today and B) because those meds come with an info sheet containing that info given by a pharmacist who asks (or normally does) if you understand everything about the meds and if you want them to go ober it with you.
“Family fun is as necessary to modern living as a kitchen refrigerator.” – Walt Disney
As for me and my house, we will serve the Lord. Joshua 24:15
R.I.P my dear Sweet Teddy. You will be missed forever. We love you.
http://www.hannahshands.etsy.com
Old 10-04-2012, 06:21 PM
CaliTerp07's Avatar
Yes, the failure rates are based on yearly statictics. So they aren'y really accurate at all. Failure rates are based on how many women use the method and how many ended up pregnant.
X out of Y women. Not per each woman.
Yes, so out of 100 women, x become pregnant using that method of birth control. Doesn't mean it "isn't really accurate at all", just that the numbers measure something different. It is completely reasonable to say that if 15 women (15%) get pregnant using condoms and 2 (2%) get pregnant using birth control pills, then .3 (3/1000) would get pregnant using both at the same time. That's basic statistics 101, independent probability.
Now, that being said, there is a good chance that most people who get pregnant while using condoms are doing something incorrectly, and would likely do something incorrectly with the BC too--so it's not a perfect science. Still, it's a reliable indicator.
Adding a secondary method (other than multiple forms of hormonal BC) is never going to increase your likelihood of getting pregnant, unless you are using a faulty method (e.g. expired spermicide) that is causing you to use the first method (a condom) incorrectly. In that case, the spermicide does nothing, and the condom's effectiveness is decreased.
An easy way to prevent that is by charting temperatures to the best of your ability, and avoiding fertile days. There is no way that can interfere with any other form of BC you use, and while it is not 100% accurate, it is a reliable indicator and can help you to prevent pregnancy, especially in conjunction with another method.
Old 10-04-2012, 07:09 PM
zoe08's Avatar
zoe08 zoe08 is offline
If the information is given to you, why should a doctor list every single thing on the sheet, when you will walk out and forget half of it a couple minutes later. That is why they give you information sheets with all prescriptions.
Being induced into labor, I am fairly certain they don't give you a pamphlet over the drug they give you, at least they didn't for me, so it is a completely different circumstance. But for prescription, I would think one would read the sheet when going on a new medication. And it is your responsibility to let your doctor AND pharmacist know what all medications you are on, so that they can make sure not to put you on something that will react with another medication, or tell you if it will interfere with the effectiveness of something. But it is YOUR responsibility to say,...hey I am also on such and such, will this medication have any effect on that?
Old 10-04-2012, 07:19 PM
sillysally's Avatar
sillysally sillysally is offline
Obey the Toad.
Every doctor that I've ever gone to has asked what meds I'm on. If they are giving you a drug that is known to interact with another drug that you are currently taking, then yes, it is their duty as a health care provider to inform you of that. That's not listing every single thing on the drug info sheet, that informing you of a drug interaction, which is sort of key information. It takes two seconds to glance at a list of meds, see that one med the patient is on is birth control, and tell said patient that the BC is going to be less effective. That, IMHO, is the bare minimum expected of a doctor.
~Christina--Mom to:
Sally--8 yr old pit bull mix
Jack--6 yr old Labrador
Sadie & Runt--12 yr old calico DSHs
Pickles & Kiwi--3 yr old white winged parakeets
Yoda--1 yr old Quaker parrot
Solo--12 yr old Senegal parrot
Sheena--Quarter Horse--3/24/86-6/23/11--Rest Easy Sweet Girl~
Labs do it in the lake.
Old 10-04-2012, 11:54 PM
Miakoda's Avatar
Miakoda Miakoda is offline
I'm really just confused.
I grew up in a middle class household. My parents were very faithful (I don't like the term "religious", but you could use it here just to get the point across). I grew up in a VERY modest household. I was never given "the talk", or anything else along those lines. Sex was NEVER discussed between me and my mom, much less my dad (horror of horrors!). I can't recall a single time the word "sex" was used in that house.
And yet, I still knew how you got pregnant, how to prevent pregnancy, and where to go to get condoms or birth control. Heck, I learned it from health/p.e. class in 7th grade (compliments of the public school system - of course it wasn't taught in much depth).
I've heard that low-income woman just don't have access to it, or they don't know about it, but....really? There's only PP billboards everywhere. The word "condom" isn't exactly some unspoken word just used in hushed tones via secret messages.
I think much of the blame lies on EFFORT. Some would have to make an effort to get the birth control. Someone would have to pass up the McD's to pay for a box of condoms instead.
Oh, and while I do appreciate that income credit one gets per child, I'd be soooo much more happy if they did away with it!!! I don't get it - my younger brother claimed less than $300 income for the 2011 year (don't ask). And yet, thanks to their 6 kids, they got back a little under $6,000 this year on their income taxs. Seriously? I've got so many curse words running through my head right now (pretty much all the time when I think of them). I don't get how you can not work, not pay taxes, and yet get back double (at a minimum) that of which working people get back!
The Hokey Pokey. That's what it's all about.
Old 10-05-2012, 12:00 AM
Planned Parenthood (under attack from so many fronts) has, for a LONG time, made low and no-cost birth control readily available, no questions asked.
Sure, there are people who have real problems with many of the readily available forms of birth control, but, for the majority of us, it's out there. And affordable.
So yeah, it's not like birth control is unavailable.
Sometimes things go awry on the material plane though . . . There are worse things than raising kids without much in the way of money, and sometimes people DO need help. It's when it becomes a lifestyle that I have a problem and I feel like I'm being held hostage to someone else's dumb choices.
Old 10-05-2012, 01:12 AM
Dizzy's Avatar
Dizzy Dizzy is offline
Ho ho ho off.
Welcome to my career lol.
I specialise in people who shouldn't have kids
People don't get pregnant from lack of birth control (its free here remember, and they still get pregnant ). They get pregnant from too much sex
I do believe its only a good thing to provide it free.... God knows what wed be dealing with if it wasn't free......
"Dogs are our link to paradise. They do not know jealousy or discontent. To sit with a dog on a hillside on a glorious afternoon is to be back in Eden, where doing nothing wasn't boring, it was peace."
Bodhi is the opposite of ignorance, the insight into reality which destroys mental afflictions and brings peace.
Owned by Bodhi Booglaoo and Fredington Holbein
Old 10-05-2012, 08:28 AM
StillandSilent StillandSilent is offline
I should also point out that people genuinely don't know. Yes, parents should be educating their children about such things, but a lot of the time, they don't. My mother is very embarassed about such things, and I think she assumed I would learn it from school.
It also doesn't help that, and I wish I was kidding about this, when I was having Sex Ed in the ninth grade, the teacher stood in front of a classroom of students, held up a condom, and told the assembled class that condoms would fail to prevent pregnancy 75% of the time, and that abstinance was the only way. I can see why people, if this is the only education they get, don't bother. Why use something that is only effective 25% of the time?
Granted, I'm stuck right in the middle of the bible belt, so most places aren't so extreme, but still.
My mother and I were watching Glee a few years ago, and a character pulled the old 'you got me pregnant in a hot tub' lie MOm couldn't believe how stupid the male character was for believing that, and I had to break it gently to her that I went to college with people who genuinely believed that it was possible.
Should people do more research? Yes. I'm not saying that there isn't a lot of personal responsibility involved, especially with the decision to bring another life into the world, but lets be realistic. Once people are told that something is the truth by a person in authority, most of them don't question it. It's human nature.
Booty Dancing In Heaven 10/13/03-9/15/12
As much as I try to be one of those easygoing 'spread your wings and fly' types, I just can't stop trying to burst people into flames with my mind.
Old 10-05-2012, 01:04 PM
Izzy's Valkyrie's Avatar
Very Food Agressive
Abstinence is unrealistic anyway....for teens and adults. It's a nice thought, but it's sex. It is going to happen. From contraception to abortion I believe there should be more low-cost options though.
or start unloading the gun before trying to shoot bullets at a bulletproof vest.
You're assuming people have no control over themselves. Sort of the same way we blame women when they get assaulted because they shouldn't have dressed a certain way; you're assuming men have no control over their base urges. It's untrue and I think with proper education people can learn how to keep it in their pants because they understand the consequences.
Izzy: BC/Retriever Mutt
Jade: DMH Cat
Tango: LH Tripod Chihuahua
Lacquer Ninja
