Old 09-07-2012, 10:48 PM
Default Car troubles
Okay so my transmission went out around... May? I got it replaced and it was under warranty.
Since then I've noticed my car feels a little jolty when I put on the brakes. It didn't before, I am 100% positive. I took it in and told them and they said I needed new brake pads and that mine were worn down a lot. But the guy drove it around and it didn't have any other problems. So we replaced the brakes and I picked it up yesterday.
Well, it still feels jolty like before! I am not sure how to describe it but I can feel it through the brake pedal. Almost feels like I'm running over bumps on the road while I'm braking.
Should I take it back in? I'm really not sure what's wrong. They said they looked over the brakes. Tires were rotated. Oil changed...
Anyone have an idea? It's driving me crazy and I know my loaner car (same make and model, different year) braked MUCH smoother than my car.
Old 09-07-2012, 10:50 PM
Kat09Tails's Avatar
*Now with Snark*
Wheel alignment? Shocks? ABS system need to be serviced?
Old 09-07-2012, 10:53 PM
Yeah I started wondering if it was the alignment. It was not terribly long ago they supposedly did a front end alignment but I can't recall when it was.
Shocks are a good guess. I wonder why they didn't check them out when I brought it in?
It's got 62K miles on it if that helps.
Old 09-07-2012, 10:56 PM
houlahoops's Avatar
houlahoops houlahoops is offline
Did you get your rotors replaced too?
If so: How much do you trust your shop? Could be that they didn't use a torque wrench when they were replacing your tires.
If not: This would be the first thing I would look at and I would suggest it to the shop.
Emily and Pippa v. Johnson-Haus RATI
"Well, don't let me be the moldy cheese in your refrigerator of hope." - Justin McKee
IMG_0242
Old 09-07-2012, 11:00 PM
joce's Avatar
joce joce is offline
What kind of car?
Is it one jolt or many? Mine was doing one big jolt when I'd hit the breaks (not always at first) and they replaced the rear end and something else just for it to come back shortly after(don't think it even did anything). Transmission place told me not to worry about it which doesn't sit well with me but that was at 100,000 and it's got well over that now.
If I have any beliefs about immortality, it is that certain
dogs I have known will go to heaven, and very, very few
persons -James Thurber
Old 09-07-2012, 11:04 PM
It's a Lexus RX350. It's several small jolts. not always when you brake, only sometimes. If I turn, it definitely does it if I'm going over a few miles per hour.
Today I had to brake fast and it worked fine but when I tried to ease on the accelerator afterwards it jolted forward. Reminded me of when the transmission went.
I took it to the dealership hoping it was under warranty or something. I really did not notice any of this until after the transmission was replaced. When the transmission went out the entire gear went out. You couldn't get the car to go at all.
Old 09-07-2012, 11:05 PM
I don't know if I got the rotors replaced... I'll have to check the receipt.
Old 09-07-2012, 11:12 PM
houlahoops's Avatar
Ask them to quote you on a rotor replacement and if it's too much, you can always have them turned or resurfaced instead until you can save up enough to get them completely replaced. New rotors tend to run around 30-50 bucks per side from a good shop.
IMG_0242
Old 09-07-2012, 11:47 PM
RedHotDobe's Avatar
aka RedHotBabe
Jolty how? Does the steering wheel shake? My rotors are warped, which causes the steering wheel to feel "bumpy," I guess. It only happens when you first start applying the brakes and then disappears. If it was just a loose wheel you'd know. I forgot to tighten a wheel down once and the whole car pretty violently shakes. Might not be as dramatic on a car with softer suspension. Mine is pretty stiff. Neither of those would cause the car to jolt forward, though.
Old 09-08-2012, 12:16 AM
Kat09Tails's Avatar
*Now with Snark*
@ 62K unless you take that baby offroading it's prob not the shocks. If you feel the vibration from your foot my guess would be something being wonky with the abs system. My old izusu had chronic abs system issues and if you braked sometimes even a little bit you could feel the catch on the brakes from what felt like through the pedal.
If it feels shakey through your hands or the body of the car I would think alignment might be weird.
