Old 07-08-2012, 05:40 PM
Paige's Avatar
Paige Paige is offline
Let it be
Default Tie out options
I'm moving into a place without a fenced in yard. I am not the type to go out with my dog and watch him go pee in the morning. At all. I don't ever leave him out for long. Bandit is not a wanderer but fact still stands. The fence is not fully fenced in and I am not risking it. So a tie out is going to be needed for 5-10 minutes of potty time in the morning. Before I've gotten Briggs ready to go on a walk.
So, what do you all think I should look into?
Old 07-08-2012, 05:42 PM
My grandmother has a laundry line tied up between the house and a tree, and has a line attached to a clip on that. Works really well for her.
Renegade: 5 1/2 year old male ferret
Harley: 5 year old female ferret
Ella: 1 year old female ferret
Nacho: 5 1/2 year old male ferret -- living out his golden years here as a foster!
Old 07-08-2012, 05:44 PM
darkchild16's Avatar
darkchild16 darkchild16 is offline
We are Home.
Weve used a double clip or the screw type clips and a long leash for a dog thats not going to challenge it.
IME it makes it alot easier when you are just doing it before a walk too because you unscrew/snap the leash and go.
Advice, most needed, is least heeded- Fortune Cookie
Old 07-08-2012, 05:47 PM
Paige's Avatar
Let it be
Oh I failed to mention my dog EATS leashes if he is tied on something he can chew through. He won't budge from the spot you left him but that lead will be no more in 30 seconds so I need something that will hold up.
Old 07-08-2012, 05:48 PM
We are Home.
Then just one of the cheap wire ones from Walmart or whatever?
Old 07-08-2012, 05:50 PM
Paige's Avatar
Let it be
I'm considering it. Should I put him on a harness instead of a collar?
Old 07-08-2012, 05:52 PM
Miakoda's Avatar
Miakoda Miakoda is offline
A harness will only enable him to pull with more force against the tie-out.
The Hokey Pokey. That's what it's all about.
Old 07-08-2012, 05:54 PM
We are Home.
he doesnt pull the tie out staci only chews it.
I would. A collar would put it closer to his mouth I would think.
Old 07-08-2012, 05:57 PM
Paige's Avatar
Let it be
He's not generally a puller just a leash eater when left alone but that is a good thing to take into consideration.
Old 07-08-2012, 05:59 PM
We've always just used the kind you stick into the ground, and a wire "leash". We've always used a collar.
