Old 07-21-2011, 10:05 AM
vmills's Avatar
vmills vmills is offline
SimAlvin
Default Looking For Solution To "Tender Toes"
We call our Cockapoo Simon "tender toes" cause he insists on pulling his paws away from anyone, even the groomer, who's cutting his nails or cutting the hair that grows in-between his pads.
Any one know to to get him to stop? The problem is that as soon as you've got the clipper ready to cut or the scissors about to clip, he yanks his paw away. I am afraid I'll end up cutting him.
valmillsy
The Boyz' Blog
Old 07-25-2011, 01:00 PM
dogs_playing_poker dogs_playing_poker is offline
Just keep working with him grab his paws and don't let go. Scold him when he he pulls and when he stops praise him from no pulling. when just being grasped he stops fighting introduce clipper and scissors. it is mostly about time don't give up it will only get worse if you do.
Old 07-25-2011, 01:46 PM
I would try to use a clicker and desensitize him. Click/treat for holding still. Start with just a couple seconfds and work up to longer amounts of time - go slow! Once he holds still long enough, add the clippers or trimmers one at a time and repeat. C/T and JACKPOT when you actually get to the point of cutting a nail. Be sure not to quick him or you may have to start all over.
Old 07-25-2011, 09:05 PM
vmills's Avatar
SimAlvin
Default Thanks for the responses
Forgot the praise part! And will try the clicker - hopefully it'll work before he gets quick clipped or stabbed in the pad.
Simon is usually very docile. His paws seem to be off limits!
valmillsy
The Boyz' Blog
Old 07-26-2011, 12:31 AM
It's actually a very, VERY common problem. So don't feel too bad Just takes a little patience.
Old 07-26-2011, 12:41 AM
Backward_Cinderella
Def. make it a positive experience, weather you use a clicker or not, and do it randomly, while you're giving out belly rubs, or cuddling, or whatever, play with those feet!!! I used to tell owners this when I groomed dogs.
Tags
cutting dog's nails
