Old 01-04-2010, 07:42 PM
2pups622's Avatar
2pups622 2pups622 is offline
Soon to Be 4 Pups!!
For Black Nail's Trim a little Bit Then look where you cut, it should be White. Keep Clipping til there is a black dot in the middle of the white. Take a tiny bit at a time.
Old 01-04-2010, 08:35 PM
Usually, where the nail starts to curve is just past the point where you should cut. A little at a time is a good idea. I like a Dremel, as it doesn't squish the nail against the quick, which also hurts....not just cutting the quick.
Caution: You can still quick them with a Dremel. Take it from me. LOL. But my dogs must be tough because it wasn't the end of the world those times I've messed up. If you look underneath, you can start to see the quick before you burn through it. It looks like the end of an itty bitty straw...sort of a hollow look to it. It will usually show through a very thin layer of nail material before it actually gets exposed all the way....even with black nails. But you have to stop and take a peek pretty often.
Anyhow, a gradual conditioning to the Dremel is a must. Here's how I did it: Reward with a favorite treat when your dog just looks at the Dremel that you've set down on the floor. (Off) If your dog gets closer to the Dremel to check it out while it's off, reward and make a fuss over her. Hold the Dremel and sit on the floor with it. When your dog comes over, repeat the reward/praise thing. Turn it on and just sit there with it. If he looks at it, reward/praise. If he comes closer, repeat. Hold your dog on your lap on the floor of have her lie next to you. Turn it on....reward. Hold her paw while the Dremel is running, make a fuss. If she is absolutely fine with all that, try just one second and one smidgen of nail material. Big treat. Call it a day. Do all that other stuff again the next day. Only move ahead as she accepts the former stuff you do with her. Try one more nail if she's okay with it. You might spread this conditioning out over several days or a week. Just take your time and don't force anything. If she wants to go away, let her. Don't force her to stay next to you. This must all be associated with a pleasant time.
Be sure to use high value treats after ever tiny success. Real meat tid bits, cheese..something really tasty.
If the fur gets caught, disastersville. So, you can also, ahead of time, put a nylon stocking (pantyhose) over her foot, pushing the nails through so the hair is held back. (If it's hard to hold the hair back while you Dremel.
Remember just 2 or 3 swipes per nail and then move onto the next, then the next and so on. Then you can come back to the first nail and so on. (once she gets totally AOK with it all) You do not want to burn her so pay attention to how long the thing sets on a nail. That heat only takes a few seconds to build up and will cause bad pain. So, make sure...just 2-4 swipes at a time before moving on. In the beginning, after each nail....a treat and a happy fuss. Then later, you can spread them out to after every paw.
When I get out the Dremel, my dogs all prance around in anticipation of fantastic treat time. LOL. We've been doing this for years, but they get treats every time.
Straight across, then just angle the edges so they're rounded a little bit and smooth.
