Old 10-08-2009, 03:20 PM
Back40 Back40 is offline
Default Pyroxide for cleaning a wound?
Sophie injured her front leg and the wound is taking longer than normal to heal. The wound is about 1/2 inch long on the front of her leg. I clean it daily with pyroxide when I get home in the afternoons because she is outside a good bit (dog door). Is pyroxide slowing the healing process? I have tried tapping gause over the wound but she just chews it off. I really don't want to go with a cone because she does use a dog door and is very easiliy traumatized (abused by previous owner).
Thanks in advance for your advice!
Old 10-08-2009, 03:23 PM
Zoom's Avatar
Zoom Zoom is offline
Twin 2.0
Yes, it is. Peroxide is ok for initial cleaning and is great for getting blood out of fur and clothing. But after that, it tends to slow the healing down as those bubbles are "eating" healing flesh as well as the damaged. I'd put some neosporin on it a few times a day and leave it alone. If she licks it, there's really nothing that will harm her and her tongue will push it into the wound further.
Old 10-08-2009, 03:54 PM
I'm really torn as when I had a carcinoma removed I chose no more cutting and stitches . My surgeon said no neosporin ! Clean with peroxide , dry and add Vaseline . It healed beautifully from inside out without scarring . But with a dog , after cleaning with peroxide , I'd tend to go with Goldbond powder . Best bet is to check with your vet .
Old 10-08-2009, 03:56 PM
dawgplanet dawgplanet is offline
i use peroxide on most cutes and bleeding scracthes and it does the job well, dont use it too often tho on the same wound it would take longer to heal.
"Don't make the mistake of treating your dogs like humans, or they'll treat you like dogs."
Old 10-08-2009, 06:47 PM
Thanks for your feedback! I thought I remembered reading somewhere on this board about pyroxide but was unable to locate it by searching. I have been using Polysporin after cleaning which unfortunately holds dirt worse than if the wound was dry. I have Gold Bond powder and will give that a try. Also going to give the vet a call for her thoughts.
Old 10-08-2009, 09:40 PM
adojrts's Avatar
adojrts adojrts is offline
I was always told by the vets to never use it on a fresh wound because it then caused damage to cells which are trying to heal. A saline solution or plain water to flush a wound is best. On an old wound a half and half solution with water works but not too often.
And never put anything except water (to flush out dirt) in a wound that will need to be stitched. I have been present countless times when someone did that, then took the animal to the vets or had the vet out (horses). The result was a pissed off Vet and a wound that couldn't be stitched that should have been.
Old 10-08-2009, 10:07 PM
GlassOnion's Avatar
Thanks, and Gig 'em.
Hydrogen peroxide kills germs as well as healthy cells. The cell itself has to get rid of Hydrogen Peroxide (H2O2 since I'm tired of typing it out), which is a byproduct of detoxification inside of Peroxisomes, which are specially modified vacoules that can contain the H2O2 and keep it separate from the rest of the cell until catalase can break it down to water and oxygen.
So if the cell itself has a specially made mechanism for dealing with H2O2, you should probably avoid putting it on a wound, at least past the initial treatment/cleaning.
Old 10-08-2009, 10:21 PM
I use the peroxide to clean it out, and then I let it sit. apply neosporin and a bandage usually does the trick.
“And above all, watch with glittering eyes the whole world around you. Because the greatest secrets are always hidden in the most unlikely places
and those who don't believe in magic will never find it.”
