Generally if it's a bad brand for dogs it's bad for cats.
Also keep in mind that dry food is not very good for cats, be in Purina, EVO or Wellness CORE. While high quality dry may give soft coats and small poop it leads to all of the same health problems as low quality dry, the most common of which being urinary tract infections (and other urinary system problems like kidney problems), Diabetes (which can in many cases disappear if the cat is fed a good wet food diet), and obesity.
dry food is very dehydrating, cats don't have a strong thirst drive like dogs (who will drink after exercise and several times a day) so they are often in a chronic state of mild dehydration which concentrates their urine and causes the urinary problems.
They must be full of carbohydrates in order to be hard an these carbs turn to sugar. This causes the cat's system to have to deal with WAY more sugar than it is designed to and this leads to diabetes. These carbs also cause obesity (or just being overweight) because the cats do not use the carbs for energy primarily, they use protein. So unless they are starved they store most of the carbs and get chubby. My cat was a bit overweight on half wet/half dry. once on all wet he shed the excess weight and is perfect now.
Dry food can often cause IBD as well, it is an unnatural texture with many unnatural ingredients that some cats are especially sensitive to. sometimes the switch to wet isn't enough, raw is often used for these cats.
So while I understand not everyone can afford all wet food diets, adding at least some wet food is very good for your cat. The higher quality the better.
