Phoebe finishes right wonderfully and heels nicely by my side. If I want to do rally-O she needs to finish left. SHE HATES IT. This has to be the hardest thing I've every tried to teach her. At first it looked promising, I used hand targeting to get her to do it and then morphed it into a hand signal, all was going well. Then when she was doing this well I would use the command I chose ("finish") followed by the hand signal. By this time is was probably the second session. It started well again. I was starting to say the command, pause and see what she'd do and then give the hand signal if she didn't do it. She did it sometimes with the word (probably guesses) and sometimes she didn't and waited for the hand signal. but then She started getting iffy. I'd say the cue followed by the hand signal (since she ignored the cue)and she'd stand there trance like. I'd say her name so she'd snap out of it and ask again and she'd do it. Then she got worse, she would do a different command (that I am teaching at the same time in an attempt to keep her from getting bored, "Front") and I'd walk away and ask again (switched to using hand signal right after the word without pausing in between again) and she'd just sit there, she ended up shutting down.
It's as if she totally forgot the hand signal, she will sit and watch me do it and then sit there without moving. I don't know if she really doesn't get it or is just bored and doesn't like this command. Should I maybe cut down to only doing it a handful of times per session?
Another question, when I was saying the cue and pausing before using the hand signal she was doing what I wanted...mostly. Instead of walking past my left leg and turning around to face forward she'd walk to the front of my leg, spin around to face forward and back up into position. How picky are judges about that, she does get in the correct position just in her own *special* way With the hand signal she would do it more proper but it was because she was following my hand as far back as it would go because I started with hand targeting. Do you think I just moved forward too fast? she usually picks things up SO quickly, I taught her two commands up to the point where she understood the hand signal perfectly in one session, she's usually very quick, it's just this one.
Any advice would be appreciated.
