R
The scars can itch like mad when they are healing. You can use an ecollar, but a really easy way to hide the incision is with some panty hose. Cut a leg off, and cut the top part near the thigh of a length so it will cover her belly. Cut slits for the front legs. Slip it on, and put her front legs through the slits. Then cut slits for the back legs. Voila. No more getting to the incision.
You can also use a T shirt the same way, but it's harder because you have to pin it up on the back and it's not as elastic as panty hose.
